Sensory Percussion 2.5 – Upgrade Now
This release includes some big quality-of-life enhancements. We have a brand-new Library, a new navigation pane called Set View, and a new Export Pack feature. Read on for the full details.
Library Updates
The new library brings a much-requested search bar. You can now search across the Sunhouse library, samples, modules and effects, and your bookmarked folders. You can even filter your results by type, for example, if you know you’re looking for a particular sequencer modules from a preset.
We’ve also added tags to all of the sounds in the Sunhouse library and sound packs, allowing you to filter them according to genre, instrument, drum type, etc. You can apply your own tags at the module, set or session level.
The library includes a new info box that shows more relevant information about whatever you have selected.
Set View
In the Edit View, we’ve introduced a new right-side panel called the Set View that gives an overview of the active set. You can search, filter, and quickly navigate around by double-clicking on any element in the Set View. We have a lot more planned for this space – this initial release lays the groundwork.
Export Sound Pack
With the new user packs feature, you can quickly turn your custom-built sets into an easily shareable sound pack. Add your own pack image, description, and tags, and then share your experiments with your friends for them to check out.
Learn more about exporting sound packs in the manual.
Other Changes
The update has a ton of other enhancements, bug fixes, and tweaks. Here are some highlights, but you can check out the release notes for all the details.
- An updated the Portal driver for Windows that lets you to select output through Main or Headphone outs when you want to use the Portal for system audio playback.
- A new "Edit Session Info" option in the File menu for editing tags, description, etc
- Many effects have a new FX Send parameter
- Overall sensor latency is lower in this release
